02-01-2006, 03:35 PM
I paint the M's on M&M's
Trans: 5 Speed Manual
My V6 sway bar vs. "03 cobra" bar new numbers Getting pissed
I just got a front sway bay in the mail I purchased from ebay. It is supposed to be an 03 cobra 27mm tubular sway bar for the front. It measures approximately 33/32" in diameter where as my Stock bar measures 17/16 in. I am just kind of lost as to how to verify what bar this is for sure. I don't know how to tell if its tubular or solid mainly, and I can't find much information on the 03 cobra bars.
Chads guide ( http://www.2kgt.com/item.php?itemid=75) only goes up to 02, and also does'nt tell me anything about the rear swaybar my 95 v6 did come with.
Any help would be appreciated.
thanks
C.q.
Originally Posted by Ashentep
I was wearing a helmet, but landing on your face doesn't really give it a chance to help.
02-01-2006, 06:12 PM
"03 cobra" bar is also heavier...
02-01-2006, 07:53 PM
The Unicorned Handler
Well it is thicker in diameter and heavier. It will make your car handle better if anything. Less body roll in the corner which means it will stay flatter.
2001 V6 Coupe Oxford White,
Kenny Brown springs,H&R sport rears,Kenny Brown strut tower brace,g-load brace,GT sway bars,Koni race struts and shocks, Maximum Motorsports lower control arms,aluminum rack bushings,Prothane End-link kit, Urethane Bushings, FRPP AL DS, Cobra Monaco race seats, Steeda graphics,dress ups, FRPP chin spoiler, Cobra R's,K&N Filter, Braille Batt,Magnaflow exhaust, Hankook tires,Steeda chrome letters, Rear Seat Delete, Mach 1 grille,Hawk HP pads.
02-01-2006, 08:15 PM
So now I am getting pissed, I measure the bar and it measures between 26 and 27 mm. It is thinner than my stock bar, it is heavier than my stock bar.
After looking around I found some information that leads me to believe that an 03 cobra bar should be 29mm and should certainly be hollow. As I understand it hollow bars are stiffer than solid bars.
I am starting to think I just got hosed on this deal. Anyone have any information on what size an 03 cobra bar should be?
Still don't know how to tell if it's hollow or not.
02-01-2006, 08:18 PM
Two Eaton blown Fords
Year: '98 V6
if i remember right, my bullitt front sway bar looked to be the same diameter as my V6 front sway bar, but it was heavier...so im assuming its better?
1995 Aspire 63hp 1.3L 5-speed - Too many mods to list
1998 V6 Mustang 4R70W - M90 blower, 310lph fuel pump, 30lb injectors, '89 Super Coupe longblock, ARP head studs, MM C/C plates, Bullitt Tokico shocks/struts, Bullitt F/R swaybars, H&R Super Sport springs, Chrome Saleen Wheels, BOI Smoked Headlights, True duals w/ Flowmaster 40's, B&M hammer shifter, J-modded valve body, 8.8 w/ 3.73's, t-lok
2000 F-150 Lightning - Airaid intake, Borla catback exhaust, 3.73 gears, 03-04 heads, comp cams 262H cams, forged h-beam rods. build #2,674 of 4,966. born on 05/03/2000. under the wrench...again
02-01-2006, 08:31 PM
Solid bars are softer than hollow bars the way I understand it but a thicker walled hollow bar would be stiffer than a thin walled hollow bar. I wish I knew the math behind it. What pisses me off is I was thinking of going to ford tomorrow to get a rear bar to match and need to know what I have up front first. PRrobably just going to bolt it up with the new one see how it feels.
C.q.
02-01-2006, 09:37 PM
Old guy
Trans: 5-speed
2003 Cobra had a 29 mm tubular front stabilizer bar and a 26 mm tubular rear stabilizer bar.
The math for swaybar calcs can be found here:
http://www.miracerros.com/mustang/sway2.htm
Diameter is the big determinant of stiffness. Hollow bars just let you get more diameter (stiffness) out of the same amount of metal (weight).
02-02-2006, 08:25 AM
Go ahead, make my day!
Trans: 5 Speed
If you put a Cobra bar up front with a stock V6 rear bar you're going to understeer like no other.
02-02-2006, 01:50 PM
Going to be getting a 94-98 solid cobra bar in the rear, or a Steeda HD. Hopefully that will counteract it.
I went ahead and installed it and its a huge improvement over stock. Still not sure if it's 03 Cobra cause it seems to measure 26-27mm. I am happy though.
