05-28-2009, 08:13 AM
hey it's that one guy
Trans: aode
302 into my 94 v6
ok i have searched but all i get is 4.6 links all i need to know is im doing a carb'd 302 no a/c. will my power steering lines fit an older box and will my tranny fit the 302? and do i need to get v8 mounts or anything. will my speedo still work and can i just take all the motor wiring out for this. and is there a way that i can just use my stock fuel pump just make a return for the carb thanks
05-28-2009, 04:57 PM
Year: 1996
Model: Mustang
Timeslip: 12.11@113mph
I think the 302 has the same power steering pump you should be good to go there.
yes your trany will fit but is not a strong at the one for a 302.
yes you need 302 motor mounts.
your speedo may not work Im' not sure on the newer model 94 and up.
no you need a carb fuel pump the your fuel pump will over pressurize the system and flood the carb.
05 Mustang GT (SCT tuner, tri-ax shifter, JBA long tube headers)
96 Mustang V6
4.3L, Procharger D1SC 16-17psi, SSX sheet metal intake, stage 3 ssm heads, 224/230 .545 lift' 1.7 RR, LT headers, Flowmaster AmericanThunder system, Performance transmission rebuild, B&M shift kit (set to hardest shift stage), 3000 stall PI stallon torque converter , 3.73 gears 31 spline axles 8.8 rear, SCT chip, UPR pro race upper and lower control arms, KYB 4 way ajustable shocks and struts.
My 96 3.8l mustang is the fastest shifting automatic in the east.
06-06-2009, 08:38 PM
Trans: aode
ok now i just need a complete list for what i need to do the swap. delete the a/c, keep the power steering.
06-15-2009, 05:52 AM
Morten M. Ramsing
Location: Kgs. Lyngby, Lyngby-Taarbæk Kommune, Hovedstadsområdet, Sealand, Denmark, Scandinavia, Northern Europe.
Model: Ford Mustang 3.8L V6
Trans: AODE
Timeslip: ZZZzzzZZZzzz...
I dont think your AODE transmission, will work with a carb. 302 motor.
What I know of, the ADOE is controlled by the OBD II computer in the car, that gets its shift control data ect. from the engine.
I dont know if a Computer programmer can by pass this ?
Best regards
Morten M. Ramsing.
My car:
1994 Mustang 3.8 V6 conv.
- Simota Filter
- MAC H-Pipe
- Flowmaster Force II Cat-back
- SPRINT Lowering kit
06-15-2009, 07:38 AM
Year: 1988
Model: Mustang GT Hatchback
Trans: t5
you will need the aod out of any aod equipped ford car. You will also need a fuel pump designed to work w/a carb.
Of all the things I've lost, I miss my Mind the most.
06-16-2009, 02:21 PM
Freakin' Wookies!!!
Model: Mustang
Trans: 5-Speed
it would be a whole lot easier to find a GT donor car
Trevor TOF ROVERT 2 =XBL
2001 Performance Red Mustang-5spd, K&N, Hood Scoop, Mach sound system, Fog Lights, Mac duals, and 2001 Chrome Cobra Wheels
06-24-2009, 02:23 PM
H/C/I 5.0 FTW
Year: 1995, 2000
Model: v8 swapped 95 and 2000 GT
Trans: manual x2
I have a 94 block that is nearly complete. Get the main harness and you would be golden. Needs a water pump/pulley and a couple vacuum tees in the stock manifolds, but that is easy stuff.
06-30-2009, 12:31 PM
" Is that a 302?" LMAO
Year: 1996
+1 for a donor car..When ever your doing a swap to any car your always not going to have everything a bolt here is missing a bracket there thats why its best to find a donor car...iv seen in Florida a few 94-95 5.0s for less than 1800 for the whole car you get the swap and then shell the parts like the fenders,doors,and the glass stuff like that make some money back...You could even swap naw NVM lolz swap the v6 back into the 5.0 lolz i dont know why i said that but anyways,sell the v6 engine you preety much make almost everything back....
Show Mods-(KM) Midnightblue,Saleen S281 spoiler,aluminun bumper inserts,Bullit fuel door,18x9 FR500's wrapped ??? B275-40-18 and F245-40-18,24inch long Flowmaster tips,front chin,SVT Cobra headlights,5% Tint,Pony Delete,Mac white face gauges,Hurst pistol grip shifter, JVC headunit, 10,000K HID's.
Engine Mods-Built 306 Low compression,Zex 100shot WET,BBK CAI,BBK 70MM TB,Cobra upper/lower ported,MSD 8.5MM wires,MSD Dist,MSD 6AL,NGK TR6's,Crane 1.7 RR's,BBK Lt's,BBK X-pipe,2.5 Flowmaster 40's Dumped,Walbro 255 fuel pump,Superchips chipped.
Drivetrain Mods-Ram Powergrip,Ford Racing aluminum driveshaft,8.8 with Ford Racing 4.10's,Steeda Tri-Ax short shifter.
Suspension Mods-BBK 2.0F 1.5R,MM CC plates,MM Upper/lower control arms.
07-01-2009, 07:05 AM
H/C/I 5.0 FTW
Year: 1995, 2000
Trans: manual x2
Very true. I bought my donor car with 9,000 miles and after selling the v6 engine/tranny/rearend and parting out the rest of the gt I actually made money on the deal to swap in a v8. Of course I blew all of that when building up the 5.0, but hey its been worth it.
