On my way home from work today, the check engine light came on, and I got the codes P0300 and P0020.
I looked up the code P0020, and this is what I found:
What does that mean?
A P0020 code refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module). That consists of an oil control valve (OCV), also called a solenoid valve and other components. Basically the check engine light and associated P0020 trouble code means that the voltage in the circuit has fallen below a set limit for a specific amount of time (varies by make/model/engine). Bank 2 is the side of the engine that doesn't contain cylinder #1.
Note: This DTC is nearly identical to P0010
OBD-Codes.com on FacebookSymptomsSymptoms may include:
Check Engine Light illuminated (Malfunction Indicator Lamp)
Rough running
other symptoms may also be present
CausesA code P0020 may mean that one or more of the following has happened:
Faulty oil control valve (OCV)
Open or short in the VVT/VCT circuit
Open or short in the OCV / solenoid valve
Damaged computer (PCM)
Possible Solutions
Some recommended troubleshooting and repair steps are:
Carefully inspect the Bank 2 VVT/VCT system circuit wiring and connectors, repair as required
With a warm engine, test the operation of the OCV, replace/repair as needed
Link:
http://www.obd-codes.com/p0020
I looked in my Haynes manual, and didnt find anything about these, can anyone help my locate the following:
- VVT/VCT system
- Oil control valve (OCV)
