Go Back   3.8 Mustang Message Board > General Discussion > Mustang Talk > V8 Swaps
Old 05-24-2010, 11:20 PM   #1
2000JDM
Year: 2000/96
Model: V6/Cobra
96 Cobra into a 2000 V6 in JAPAN!!!!
Hey. I came across this site thanks to the oracle (Google). Glad to see all the support here. I had a 2000 GT when I lived in the States, had to do some stuff to it because it's a Mustang...I'm fine with that and I feel comfortable with my level of experience and basic automotive knowledge and mechanical skills (thanks Dad). Anyway here's the situation.
I bought my girlfriend a 95 GT convertible out here in Japan...nothing but problems, in fact she's given up on it and so have I, but before we came to the decision of selling it she needed a driver’s side window. Parts are difficult if not impossible to come across out here. So there I was driving down the road one day when I saw the back end of a Mustang with a love seat sitting on top of it. Noticed that the driver’s side window was intact so I approached a Japanese dude who was outside. I don't speak Japanese but my girlfriend does (well not when it comes to mechanical stuff, same as in the States). So by the time she got done asking the guy how much he wanted for the window, she told me he wanted 20,000 for the whole car. I was like what??? Just the window. She said it was 20,000 Yen which is $200. I told her tell him OK. Deal was done. After looking at it closer I noticed it had Dual Exhaust. So I popped the hood and there it was, a big ole Cobra looking right at me saying "Get this F**'n love seat off me". So I started looking for a donor car to drop this snake into. Found a 2000 V6 for $4000, which is a steal out here BTW. the reason it was so cheap was because the A/C and brakes don't work. NP, cuz the Cobra will take care of all of that. Started the Cobra up after 6 years of sitting (with a love seat on it) without hesitation the Beast was alive. Shut her down after a gentle warm up, no leaks, so I got a guy doing a once over to replace the seals and give me the thumbs up on the internals.
Any tips tricks or things to be aware of while I plan out this swap?? Thanks again.
2000JDM is offline   Reply With Quote
Old 05-24-2010, 11:37 PM   #2
SchwaebzGT
Rollin on GT4's
SchwaebzGT's Avatar
Model: 4.6L
Trans: 4R70w
Send a message via AIM to SchwaebzGT Send a message via Skype™ to SchwaebzGT
out of curiosity, can the cobra be driven as is, is there something wrong wiht the car now, besides a loveseat on top of it?
****, yen is weird compared to dollars
1999 Mustang GT
SchwaebzGT is offline   Reply With Quote
Old 05-25-2010, 12:45 AM   #3
2000JDM
Year: 2000/96
Model: V6/Cobra
looks like the Cobra hit an inanamate object at high velocity. Knocked the whole passenger wheel into the door. had to put a winky spare on it just to get it on the tow truck. Luckily under the hood everything is fine except i noticed the most curious thing. apparently the smog pump feeds into a T fitting and then to two, what look like acuators. Well the T fitting had been cut out. not remomed, CUT. so i have to try and order all new hoses from the smog pump to those actuator dealy-o's.
Old 05-25-2010, 03:01 AM   #4
mczest
I Like Turtles
Trans: T-5
Send a message via AIM to mczest
i wouldve done a smog pump delete lol
mczest is offline   Reply With Quote
Old 05-25-2010, 03:42 AM   #5
taylor0987
taylor0987's Avatar
Trans: 5
Timeslip: 14.0@100
Send a message via AIM to taylor0987
the 94-98 vs 99-04 cars had some extreme changes in how the wiring, fuel system, and some other things were handled
you're going to decide what your approach is
if you want to leave some of the wiring in the car and keep the fuel system the same in the 2000, then you will want to find a 99-04 v8 donor car and will need to get a lot of the wiring and computer from that to swap into the v6
if you don't mind stripping both cars, then you can use almost all of the wiring from the 95 car-- that means everything under the dash, most of the wiring going back to the trunk area, lots of the wiring in the trunk, the wiring going back to the fuel tank; you'll also need to run a return fuel line from the engine compartment to the trunk.
taylor0987 is offline   Reply With Quote
Old 05-25-2010, 05:32 AM   #6
2000JDM
Year: 2000/96
Model: V6/Cobra
Thanks taylor. that's exactly the kind of info i'm looking for. getting a 99-04 GT donor is out of the question unless i get one from Main Land Japan. Not gonna drop another 8-9K. I will use most everything from the 96 Cobra minus the interior and out side body parts of course. I did see something very obvious which I'm wondering how to tackle it. On the V6 there's this huge cylinder attached to the brake lines, hydroboost or something like that? on the Cobra you can hardley see a cylinder at all. I know i have to change it because the DOHC won't fit with the V6 booster, but anyone know how both attached to the firewall? looks like a singe stud and nut and 3 rivets, could be wrong. thanks in advance.
Old 05-25-2010, 02:00 PM   #7
taylor0987
taylor0987's Avatar
Trans: 5
Timeslip: 14.0@100
sorry I got mixed up with the 95 vs. 96 thing, substitute "96" for what I put in that post
vacuum=big; hydroboost=small
the v6 uses a vacuum brake booster. that is the big thing you see
the fasteners holding the brake booster in the car on the v6 are 4 nuts on the *inside* of the car. they also hold the brake( and clutch for manual trans) pedal assembly in the car.
the 96-04 v8's use hydroboost (hydro=hydraulic) the brakes are powered using pressure from the power steering pump. that has the smaller thing behind the master cylinder.
you need to swap the hydroboost setup from the cobra to the v6 body for the cobra engine to fit.
Old 05-25-2010, 02:12 PM   #8
chaoticdismay
the rippin and the tearin
chaoticdismay's Avatar
and it's not just the HB from the engine bay, the pedal assembly is also different and will need to be swapped as well.
Rico - 330/309 @ 7psi
chaoticdismay is offline   Reply With Quote
Old 05-25-2010, 03:46 PM   #9
2000JDM
Year: 2000/96
Model: V6/Cobra
Awesome. That's some good info. I figured it was a type-o 95/6. It's funny that my Japanese friends call me the "Mustang Guy", if they knew guys like you I'd just be an aveage Joe.
Thanks again.
I was planning on switching pedal assemblies also becasue the V6 is an Auto and the Cobra obviously is Manual, but it's good to know how everything works.
* here's a little Japanese trivia: Did you know that in Japan there are two types of Drivers Licenses for driving an automobile? One is for an Auto an one is for Manual. And to get your Japanese Drivers License will cost around $3000 per flavor.
Old 05-25-2010, 04:48 PM   #10
corydoitch
wat
corydoitch's Avatar
Model: Splitport
Trans: 5 Speed
Send a message via AIM to corydoitch
This is going to be a good thread, I love export cars.
1998 Splitport Turbo V6-T56 and IRS on the shelf
2001 Audi A4-Sold
1993 Infiniti G20-SR20, daily beater
1984 BMW 318i-$100 track slut
corydoitch is offline   Reply With Quote
Old 05-25-2010, 05:27 PM   #11
2000JDM
Year: 2000/96
Model: V6/Cobra
I didn't realize that there was so much interest in JDM Mustangs. Wish I would have known....saw a 97 V6 in the junkyard here a few months back.... realize now I should have gone in and stripped it. I'll keep my eye out for any more at the yards for y'all.
Old 05-25-2010, 05:31 PM   #12
atlanticblue98
Bazinga!
atlanticblue98's Avatar
Trans: 4R70W Automatic
Timeslip: 16.6@83mph
Send a message via AIM to atlanticblue98
the most popular part is the tailights with the amber in the lenses.
oh and the JDM sun visors are cool
atlanticblue98 is online now   Reply With Quote
Old 05-25-2010, 05:34 PM   #13
2000JDM
Year: 2000/96
Model: V6/Cobra
If you guys know anyone moving to Okinawa and want to buy my GT here's a link:
http://www.okinawayardsales.com/item...temId=14842353
Old 05-25-2010, 07:42 PM   #14
FordMotorsports
Trans: t3650
I would start by stripping the interiors, then start the harnesses from the tails forward. Then the fuel system, dash, brakes, etc etc. I am gonna say for sure you will have to turn the pats off with a tuner, because it might be a problem to get Ford to do it. Sounds like you got a hell's good donor car. Good luck.
Mods: Roush S3 kit; 4V Swap, o/r x-pipe, Magnaflow side exhaust, tri-ax, jlt, 8.8 with 3.73s, Mac upper and lower control arms
12.83 @ 108.95 2.0 60ft
FordMotorsports is online now   Reply With Quote
Old 05-25-2010, 08:06 PM   #15
punypony
Twin Turbo trainwreck
punypony's Avatar
Trans: T-5
Timeslip: 12.64@106.95
if you have the keys to the other car you should be able to remove the lock cylinder, and you will obviously need the cluster and computer anyway, which would negate the need to mess with pats.
punypony is online now   Reply With Quote
Old 05-25-2010, 08:12 PM   #16
FordMotorsports
Trans: t3650
"Maybe" lol
Old 05-25-2010, 08:14 PM   #17
punypony
punypony's Avatar
Trans: T-5
"Maybe" lol
yes, i suppose should would have been a bit more accurate than "would"
Old 05-25-2010, 09:28 PM   #18
2000JDM
Year: 2000/96
Model: V6/Cobra
Thanks. Sounds like a good start. Oh did I mention in the midst of the transfer of electronics, drive train, etc. I plan on changing the color to a gunmetal or maybe dark shadow gray. So after I strip the V6 it's off to the paint shop and once it gets back it'll be a slow, methodical approach changing everything over while I bust rust and repaint. I plan on using all components from the Cobra, including ignition, door locks etc. I think that's the easiest and only way. There is no Ford support out here. The closest thing we got is a Mazda dealer with a "Ford Service" logo hidden in the Mazda Service Dept. Took my 95 Stang there once and they had it for 2 weeks before they told me they couldn't help because they had to call up to Tokyo everyday to get step-by-step instructions. That's why I appreciate all your help here. Mustang owners are a unique breed. And to speak to the donor car, both cars are a pretty good find in my humble opinion. Both have about 53,000km which is around 32,000 miles. Thanks Guys...and Gals if applicable.
Old 05-28-2010, 06:48 PM   #19
SchwaebzGT
Rollin on GT4's
SchwaebzGT's Avatar
Model: 4.6L
Trans: 4R70w
srsly, if you start doing that, you could make some money on here
1999 Mustang GT
Old 05-31-2010, 09:54 AM   #20
Sanchez
I CAN HEAR GOD
Sanchez's Avatar
Year: 2008
Model: Mazdaspeed 3
Trans: 6 Speed
Thats not true.
flickr
Originally Posted by Concerned
Imagine your son in all his autistic glory swinging a broom around and chanting to the devil. Praise Allah I say.
Sanchez is offline   Reply With Quote
Old 05-31-2010, 10:03 AM   #21
FergusonRed6er
Call me Bruno
FergusonRed6er's Avatar
Model: Bullitt
Trans: TR-3650
Send a message via AIM to FergusonRed6er
Originally Posted by Sanchez View Post
Thats not true.
I also just looked it up: http://en.wikipedia.org/wiki/Driving_licence_in_Japan
There are many types but I don't see anything about manual and auto.
O/r H-pipe, 4.10 gears, MGW Short throw, Vredestein 315's, SCT SF3 tune.
FergusonRed6er is offline   Reply With Quote
Old 06-01-2010, 03:30 PM   #22
2000JDM
Year: 2000/96
Model: V6/Cobra
Thats not true.
Ummm.... I live here. My girlfriend just got her license. She's can only drive an auto. She has to take another test to drive a manual. It wouldn't make sense to have two separate tests if one license would accommodate both license types.
Old 06-01-2010, 03:33 PM   #23
2000JDM
Year: 2000/96
Model: V6/Cobra
I could go update wikipedia for you if you want. I don't trust everything on wiki, since people like you and me can go and edit stuff. It is a good reference but i wouldn't consider it the end all. Might just be Okinawa Japan and not Mainland.
Old 06-01-2010, 03:40 PM   #24
Kurisu
Resident Fun Size
Kurisu's Avatar
Year: 2005
Model: v6
Send a message via AIM to Kurisu
Most countries (Japan included) have the licenses by the vehicle type, not by the transmission.
http://www.koyama.co.jp/english/english_01_03.html
Kurisu is offline   Reply With Quote
Old 06-01-2010, 04:19 PM   #25
2000JDM
Year: 2000/96
Model: V6/Cobra
My apologies. I could be wrong. I'm gonna go down to the Land Transportation Office and get the actual scoop. I haven't had to deal with an actual Japanese License because I'm with the U.S. Military and we just take a written test and get a SOFA (Status of Forces Agreement) License.
Old 06-01-2010, 05:08 PM   #26
Sanchez
I CAN HEAR GOD
Sanchez's Avatar
Year: 2008
Model: Mazdaspeed 3
Trans: 6 Speed
Thats cool man I mean its not like I did a two years over there myself or anything. I must be totally ignorant to how I got my license over there and therefore completely talking out of my ass. I also guess every available resource saying youre wrong must also be incorrect. My bad man, Ill never doubt you again and just accept the fact that Japan and Okinawa must charge $3000 for a license depending solely on the transmission because you said so.
flickr
Old 06-01-2010, 09:10 PM   #27
2000JDM
Year: 2000/96
Model: V6/Cobra
Wow. Take a chill pill dude. I said I could be wrong. I was going off my experience and what my girlfriend just got done going through. You said you did two years over here? in the military? if so, you know as well as i do things are different for us, "Professional Drivers". And I'm not saying every resource is wrong and I'm right, I was just saying that wikipedia is not 100% correct or 100% complete always. Doesn't really matter anyway because this tread is about a Mustang conversion which has nothing to do with Japanese licenses. MY BAD for even bringing it up.
Old 06-01-2010, 09:18 PM   #28
2000JDM
Year: 2000/96
Model: V6/Cobra
Again, something that doesn't make sense is if you look at the price list specifically where is says "License Obtained" they have AT and MT and there are two different price totals for each. Why would there be two different training programs and "License Obtained" if A single license would encompass all? Can anyone explain that?
http://www.koyama.co.jp/english/english_02_01.html
