Go Back   3.8 Mustang Message Board > 1994-2004 Mustang Tech > 3.8L Powertrain Tech > Electronics
Old 05-31-2010, 02:57 PM   #1
lilnicky068
Two-tire Fire! :)
lilnicky068's Avatar
Send a message via AIM to lilnicky068
Intermittent clicks, beeps, and flashes & car wont start
When i turn the key to start the car, all i can hear is a relay clicking (not the starter clicking). also, with the key in different positions, i hear random clicks from different relays (both under the hood and under the dash) and the dome light flickers with clicks sometimes. when i turn on the wipers, a relay clicks and the wipers move in tiny increments along with the clicks. everything is very intermittent though. sometimes things work, sometimes they dont, but the car will not start at all. wtf is going on? i know low voltage on a battery can cause some strange things, but i put a volt meter and it and its reading 12.5 volts right now. i also had jumper cables hooked up to the battery for about 10 minutes and that didnt help either. i am so lost.
lilnicky068 is offline   Reply With Quote
Old 05-31-2010, 07:44 PM   #2
leo2hot4tv
2hot4GT:LOL
Year: Y2k
Trans: Manual T-5
Timeslip: 0.00
Send a message via ICQ to leo2hot4tv
It's most likely the battery. A volt meter won't tell you if the battery is dead or not. If the battery is completely gone, jumper cables won't work. Go to an auto parts and get the battery tested. Check your terminals for corrosion and check it they're tight too.
Known Mods:CAI, Short Throw, Steeda Lowering Springs, GT rear sway bar,1/2" Intake Spacer, Autometer Phantom Vac gauge, White face gauges, Cobra front bumper, GT rear, 17x10.5 Anthracite Bullitts , Custom H w/ dual Magnaflows,cat delete, Sony Head Unit, Kicker 400 Watt amp, 1- 12" Sony X-plode.
leo2hot4tv is online now   Reply With Quote
Old 05-31-2010, 07:50 PM   #3
Deathdeisel
New Guy?
Deathdeisel's Avatar
Model: Mustang
Agreed, sounds like your battery is hardly putting out any power, and the random clicks is your cars computer restarting trying to run the normal startup, just about 5 times because of re-boot.
Deathdeisel is online now   Reply With Quote
Old 05-31-2010, 09:14 PM   #4
NorthWest3.8
Cool Whip
NorthWest3.8's Avatar
Year: 2004
Model: Ford Mustang V-6
Trans: 5 Speed manual
Timeslip: NA
I had a very similar problem, turned out to be corroded terminals. Take some sandpaper to it and the see if it works.
I will live forever or die in the attempt
NorthWest3.8 is offline   Reply With Quote
Old 05-31-2010, 10:03 PM   #5
sircrashalot
Caribbean love 2 eat rice
sircrashalot's Avatar
Year: 1996
Model: Ford mustang
Trans: AuToMaTic!
Timeslip: 1 day!
agree with everything, i run a huge power hungry sound system,
massive drainage of the battery will cause that(your car still feeding off the battery even after car is off(split wiring somewhere ground it self)
corroding will cause that
dead battery will definitely cause relay to click but no action it like plugging a 12 volt battery to a 24 volt item, just enough to actuate but not function
Mustang 96
Appearance mod: Saleen complete 7 piece kit, 2 inch drop dual exhaust+chrome 18" tip , full black paint, Interior neon, Dash white face indigo, HID kit, 8000k low/8500k high's, Projector headlight, Tinted Tail light, Cobra R hood, GT500 hood pin,
Entertainment: 2 Kicker L5's, custom solid box powered by v900xd, 4 infinity speaker powered by MTX RT amp, Kicker tweeters , Indash Dvd 7" motorized, wireless box controlling all remote turn on for amps
Performance mod: CAI, big 3,Dual exhaust 4 cats h pipe(soon),
sircrashalot is offline   Reply With Quote
Old 06-01-2010, 01:52 AM   #6
MMR
Morten M. Ramsing
MMR's Avatar
Location: Kgs. Lyngby, Lyngby-Taarbæk Kommune, Hovedstadsområdet, Sealand, Denmark, Scandinavia, Northern Europe.
Model: Ford Mustang 3.8L V6
Trans: AODE
Timeslip: ZZZzzzZZZzzz...
lilnicky068lilnicky068lilnicky068: I also had the same problem, and it also turned out to be the battery and the connectors/terminals..To be honest I dont know what they are called in english, but the poles that you connect to the battery and the battery had gone bad.
But both they are pretty easy to replace.
Best regards
Morten M. Ramsing.
My car:
1994 Mustang 3.8 V6 conv.
- Simota Filter
- MAC H-Pipe
- Flowmaster Force II Cat-back
- SPRINT Lowering kit
MMR is offline   Reply With Quote
Old 06-01-2010, 07:41 AM   #7
lilnicky068
Two-tire Fire! :)
hell yea, that makes me feel better about the situation. i just figured jumping the battery for a while would have taken care of it if that was the issue. i guess ill make a trip to autozone and have it tested.
Old 06-01-2010, 07:51 AM   #8
NorthWest3.8
Cool Whip
Year: 2004
Timeslip: NA
Did you check the terminals for corrosion?
Old 06-01-2010, 07:53 AM   #9
lilnicky068
Two-tire Fire! :)
yes the posts and rings are squeaky clean. used one of those nifty brush tools to clean them up.
Old 06-01-2010, 07:54 AM   #10
NorthWest3.8
Cool Whip
Year: 2004
Timeslip: NA
Yeah those work really well.
Old 06-01-2010, 02:51 PM   #11
lilnicky068
Two-tire Fire! :)
just got back from autozone. the battery tested good... since earlier i have checked both fuse/relay boxes and they both seem to be in good order. i REALLY have no idea where to go from here. its just acting so weird... if i turn the key back, the radio comes on as it should, but if i hit the lock switch or the window switch the radio goes off (as well as everything else). im lost. any more ideas guys?
Old 06-01-2010, 03:19 PM   #12
leo2hot4tv
2hot4GT:LOL
Year: Y2k
Trans: Manual T-5
Timeslip: 0.00
Do you have access to a similar crank battery? I had a ****ty battery once and those bastards at Discount kept trying to pull it off as good. Some of them are also genuinely clueless. It all points to the batt though.
Old 06-01-2010, 03:23 PM   #13
(SilentMember)
(SilentMember)'s Avatar
Year: 1996
Trans: t45
Send a message via AIM to (SilentMember) Send a message via MSN to (SilentMember)
Take a multimeter and make sure all your battery connections and the CABLES are good. I use the continuity mode (makes a beep if theres good connection) My lightning did the same thing and it was a bad positive battery cable.
96 Mystic Cobra #441
02 True Blue Lightning
(SilentMember) is offline   Reply With Quote
Old 06-01-2010, 03:24 PM   #14
lilnicky068
Two-tire Fire! :)
No i dont have another battery i can try and i'd really hate to buy another one just to try it
Old 06-01-2010, 05:21 PM   #15
lilnicky068
Two-tire Fire! :)
smart man i did as u suggested and found that there was no continuity between the negative terminal and where it grounds to the chassis. disconnected the terminal from the cables, cleaned them up a bit, reconnected the terminal and now everything is working fine. crazy how that made everything go haywire. i figure if it had to do with the ground connection it would either work or not work (not be somewhere in between) but i guess not. thanks a lot guys!
Old 06-01-2010, 05:38 PM   #16
(SilentMember)
Year: 1996
Trans: t45
Glad you got it fixed A multimeter is my best friend!
