Go Back   3.8 Mustang Message Board > 1994-2004 Mustang Tech > SN-95 Chassis / Body Tech > Interior & Stereo
Old 07-09-2004, 08:52 PM   #1
kevin@volpaz
Official 3.8 Sponsor-Kmonie360
Trans: Audi TT 5-speed
Send a message via AIM to kevin@volpaz
Instructional On installing a Push Button Starter
Thanks to SFrymyah:
I installed mine today and made the needed changes so that this applies to the 94-98
The switch i bought came from Autozone, made by pilot. it was $30, but worth the money since you get instructions, a nice wiring harness, a chrome switch, optional mounting plate, 3 lense covers (red, blue and clear) and a swivel base so you dont have the tear it all apart if you want to change the colors. the harness consisted of Black, Red, Yellow, and White Wires.
Tools You Will Need:
Set of wrenches
Wire Cutters
Screw Driver
Electrical Tape
Box Cutter
What You Need To Do:
1. Remove the Kick Panel and the Metal Piece Underneath it.
2. find the Black box with wires coming out of it (it has a grey top with a screw holding it in. Be careful taking it off, I broke mine all to ****. I didnt bother trying to get it back on because 1) it was broken and 2) the wires were so large, and well restrained, there wasnt a lot of point in putting it back.
3. Once that is removed you will see 5 bigger Yellow Wires. These are all Constants, You can hook any of these into the buttons power wire.
4. Use the Wire Cutters to strip about a half of an ich of the wire coating off. Then take a wrap the wire from the relay (in my case red) around that striped spot and then use electrical tape to hold it in place. Another way to do it is to take your Box cutters and strip the wire away in one spot. this keeps you from having to completely cut the wire, and turned out to be really convienent.
5. Next look for a Black/green wire (this is what it was on the 98). Take the yellow wire from the relay and do it the same way as the red wire.
6. The next one is the starter wire. Which is white/pink and a bit (not much!) smaller than the rest. you can splice into this one the same way as above, but i really DO NOT recomend it! Could lead to later problems!
7. After everything is hooked up, youre going to want to find a ground. I found that the best place was on the metal peice that remains after you took everything apart from under the steering wheel. i simply hooked the ground wire on to one of the screws and bolted it down. its easily hidden, and easily accessable.
8. Now that youre wired up, connected everything do the spot you located on the dash to mount it. the kit should have come with an optional bracket, but if you decide to put it on the dash, the best place is on the guage cluster bezel. i found that all the included wires are the PERFECT length and do not need to be altered at all to get to this spot. not to mention, it looks really good in the car too
9. To use the swich you will need to put ur key in, turn it so that all the power in the car comes on and then hit the button. The engine should start.
sorry attempt at a 99-04 instructional
This is Probably my most favorite part of my car now. There are two ways u can install it. One with the key turning still working or disabling the key starter and just using the button all the time. I decided to keep the key working just so i wouldn't have any problems in the future.
Also I bought the autozone speacial "no name" swich. Came with the Swich, Relay, with four wires coming from it. Black, Red, Yellow, White.
Set of wrenches
Wire Cutters
Screw Driver
Electrical Tape
3. Once that is removed you will see 3 Yellow Wires. These are all Constants, You can hook any of these into the buttons power wire.
5. Next look for a Red/Black wire or a Red/Light green. They both should be in there. Take the yellow wire from the relay and do it the same way as the red wire.
6. The next one is the starter wire. Which is white/pink and a bit smaller than the rest. On this one i used the same method as above to connect the relay's white wire to it. But you can just cut the white/pink wire and connect it straight to the white one from the relay(This will disable the key from being able to start the car).
7. After this is finished a good place to ground the swich is on the little metal piece located under the metal that is under the kick panel. Thats a mouthfull but it's there.
8. Once the wiring is done connect the swich to the ground and the relay and mount it in ur car. I chose next to my cluster on the right side. But there are plenty of places to do it.
there are some pics below. Hope this helps.
Kevin ------------- Volpaz.com -------------- sales@volpaz.com
Previously known as Kmonie360
kevin@volpaz is offline   Reply With Quote
Old 07-12-2004, 12:05 AM   #2
Hancock
Hancock's Avatar
Year: 1990
Send a message via AIM to Hancock
what exactly is the purpose of a push button?
Hancock is offline   Reply With Quote
Old 07-12-2004, 12:35 AM   #3
Sean
incapable of error
Sean's Avatar
Year: 2004
Trans: STi
Send a message via AIM to Sean Send a message via Skype™ to Sean
I did something similar in my car when my key broke in half. However since my car is keyless, I had to add some extra stuff to power the accessories on by switch. It was pretty easy and only took about 5 hours to pull off with a couple relays and a multimeter.
Sean is offline   Reply With Quote
Old 07-14-2004, 04:50 PM   #4
kevin@volpaz
sweet... The push button was in sportscars in the 60s and 70s mostly. I know they are in the new s2000s. The main purpose is because it's cool to start ur car with a push of a button... I'd love to someday do away with the key all together. But i need to figure out how to bypass the security system somehow. What i'd really like to do is install the starter that is in the new boats what malibu puts out. Instead of a key u have a code to start the car. That sounds so much easier
Old 07-14-2004, 06:25 PM   #5
InfernoStang
12's are slow
InfernoStang's Avatar
Year: 03 Evo
Trans: cinco speed
Send a message via AIM to InfernoStang
awesome mod
InfernoStang is offline   Reply With Quote
Old 08-16-2004, 10:26 AM   #6
chad
QuickSilver
chad's Avatar
Send a message via AIM to chad
I got this done the other night, this is a really cheap and fun mod to do!
Performance: NX EFI 75 wetshot, Steeda Sport springs, Steeda Tri-Ax, MAC Exhaust w/ 2.25 Hpipe(UDP & Ram air to come)
Appearance: Sunroof, Cobra Chrome wheels, kumho 255's, 20% Tint,Chrome billet grille, Infinity Sound System w/ Alpine HU, Custom Fiberglass trunk display.
14.8 1/4mi.
chad is offline   Reply With Quote
Old 08-16-2004, 12:05 PM   #7
LtdMustang232
The Boss.
LtdMustang232's Avatar
Year: 2004 A4
Trans: 5 spd
is that like a neon spot light or sumthing?
ISSA Certified Personal Trainer
NASM Certified Personal Trainer
LtdMustang232 is offline   Reply With Quote
Old 08-16-2004, 02:42 PM   #8
chad
QuickSilver
chad's Avatar
no, thats where I put my button for the push start
14.8 1/4mi.
Old 08-29-2004, 06:20 AM   #9
chrismullins99
chrismullins99's Avatar
Send a message via AIM to chrismullins99
Do u still need the key in the ignition to start the car? Cuz otherwise i could see this as a major security issue.
chrismullins99 is offline   Reply With Quote
Old 08-29-2004, 07:20 AM   #10
chrismullins99
also do u have to just use a momentary switch or can it be one of those flip switches with the cover?
Old 08-29-2004, 02:12 PM   #11
chrismullins99
ignore above ??s kmonie helped me out, if anyone else wants to know u have to use a momentary switch and u can have it either start wit the key also or wit just the button
Old 08-29-2004, 02:27 PM   #12
KTBug
- Kris -
KTBug's Avatar
Send a message via AIM to KTBug
If you have to have the key in the ignition to use the push button, why not just go ahead and turn the key a llittle more to start the car?
:thumbdown :thumbdown
It is impossible to make people understand their ignorance; for it requires knowledge
to perceive it and therefore he that can perceive it hath it not.
Jeremy Taylor (1613-1667)
KTBug is offline   Reply With Quote
Old 08-29-2004, 03:12 PM   #13
StangDoo98
StangDoo98's Avatar
Trans: Slowmatic
ktbug- well its just something that adds a cool factor to the interior of your car and when starting it.
StangDoo98 is offline   Reply With Quote
Old 08-30-2004, 09:01 PM   #14
AZ420devil
does it make a difference if you drive stick or not? has anyone set this up on a stick set up? I assume it's the same, accept, turn key (power on), engage clutch and push button.
Also, should I disconnect the battery before attempting this?
Also, why does it say red/black or red/light green, are both those wires in there or is this for diff years?
I'm full of questions.
AZ420devil is offline   Reply With Quote
Old 08-31-2004, 05:25 AM   #15
kevin@volpaz
Mine is set up on a stick
and when they say red and two other colors just means that ford uses different wires all the time... so u never know
Old 11-08-2004, 08:54 PM   #16
big rick
Trans: 5-speed
Send a message via AIM to big rick Send a message via MSN to big rick
I think it is Cadillac that has a thing where it is pushbutton and you don't need to have the key...what you do need is a credit-card sized activator thingy that is sensed within a certain distance of the car...so you can just keep it in your wallet and when you get in the car...push the button and go...I've always wanted to install something like that into my car...can't wait til they do something like that for the aftermarket...
Is it possible to get a pushbutton kit that instead of a button it is a switch just like in the nascar cars?...I think that would be cool...maybe I could actually use one of those little spaces below my radio that is just a black spot right now...
p.s.-sorry for starting up another old thread...its always been at the top though...
This post has been brought to you by Rick, Have a Nice Day!
-2001 Mustang Convertible - black ext. black top tan int. - 5 speed - stock
MCC is the coolest musclecar site ever!
big rick is offline   Reply With Quote
Old 11-10-2004, 01:42 PM   #17
meltn02
I removed what I figured was the kick-panel (the panel to the left of the dead pedal where the hood release is, and saw no black box, or anything like that 2nd picture. Im probably looking in the wrong spot, any help?
meltn02 is offline   Reply With Quote
Old 11-10-2004, 02:04 PM   #18
Volpaz.com
Former Sponsor
Year: 03
Trans: 5-speed
Send a message via AIM to Volpaz.com
the panel that is right underneath the steering wheel...its like right above your shins when your driving.
-Tim
Volpaz.com is offline   Reply With Quote
Old 11-11-2004, 10:38 AM   #19
uiostheo
Cantankerous Phil
Send a message via AIM to uiostheo
I was wonderin if you could give a lil more detail to your instructions because I have to do this mod in one day as I drive my car to school everyday so I really don't want to mess it up makin it so that I cannot start the car
uiostheo is offline   Reply With Quote
Old 11-11-2004, 11:56 AM   #20
Volpaz.com
Former Sponsor
Year: 03
Trans: 5-speed
it takes less than an hour to do...it took us like 20 minutes...all you have to do is know how to splice into some wires and you're set
Old 11-11-2004, 11:59 AM   #21
uiostheo
Cantankerous Phil
I haven't actually looked under the dash yet to check everything out, but did you use these same instructions to do it, with no problems?
Old 11-11-2004, 12:00 PM   #22
uiostheo
Cantankerous Phil
also where did you get your push start button, cause I like the blue but I would prefer one with a black rim around it
Old 11-11-2004, 12:02 PM   #23
Volpaz.com
Former Sponsor
Year: 03
Trans: 5-speed
I'm the one who helped HIM install it, kmonie360
Old 11-11-2004, 12:03 PM   #24
Volpaz.com
Former Sponsor
Year: 03
Trans: 5-speed
autozone
Old 11-11-2004, 12:05 PM   #25
uiostheo
Cantankerous Phil
alright sweet but since you seem to be right by the comp, considerin you responded in like 2 min, about how much do they run?
Old 11-11-2004, 12:09 PM   #26
Volpaz.com
Former Sponsor
Year: 03
Trans: 5-speed
i forget how much he paid...like 15bucks or something
Old 11-11-2004, 12:11 PM   #27
meltn02
I got mine at autozone last night, it has 3 different colors (red blue and clear/white) and was 29.99. Its got everything all ready to wire up. There is a aluminum bezel around it that you can keep on or take off as well.
Old 11-11-2004, 12:13 PM   #28
Volpaz.com
Former Sponsor
Year: 03
Trans: 5-speed
sweet, post pics in this thread when you're done!
Old 11-11-2004, 03:28 PM   #29
StockStang19
Team stock taillights
Trans: 5-Speed
they have some at extremeeffects that say engine start but are a bit pricy
http://www.extremeeffect.com/38pushbuttoninfo.html
Car under construction
Done so far--MGW T-handle shifter knob, mac whiteface gauges,Mac AC white face plate, various interior billet items, flowmaster dual exhaust,K&N FIPK CAI, 17"cobra rims, Jamex shocks and struts,Thor 2 way lcd paging car alarm w/remote start, Pro 5.0 shifter,bullit pedals
On the way bolt ons
StockStang19 is offline   Reply With Quote
Old 11-28-2004, 11:51 AM   #30
Fordmustanglove
D.E.P
Fordmustanglove's Avatar
Trans: Stick
Send a message via AIM to Fordmustanglove
i got mine from Ignited. im glad i i found some decent instructions so i can intall WOOT!
Fordmustanglove is offline   Reply With Quote
